Connecting chain
  • Connecting chain
    I'm not sure if I've dun goofed but I need to some help with my chain.
    I bought a new one and asked for one for my bike, they gave me one that was 120 links and said it would need to be cut down. So when it came time to put the chain on I cut it down to the required 110. This is where I ran into the problem.
    It's a clip link type chain. What came in the box with it assumes you're not cutting the chain down, so the clip link sits over two rollers (not sure if that's the right term).
    This is what the chain looks like at the moment
    Click image for larger version
    These are the ends of how it came originally
    The link that came with the chain
    Now obviously that link won't fit and it would be missing a roller. Is there anyway of connecting it using a single rivet/thingo?
    oops clip one ... I'll be quiet
    what I wrote - need to put a link in that needs spreading from a punch.
      Your missing the slider thingo that goes over the third pic link. There should be three pieces in that link kit. Sorry I can't be more detailed. I just replaced my chain on the weekend.
      Originally posted by darkfibre
      Just sync the oil changes with her monthly cycle and get all the grumpyness over with, leaving the rest of the month clear sailing.
        You'll need to drop another link on the top pic RHS end to get the joining link to connect.
        As Viper suggested - you'll need to use a punch or a link tool to set this new link and 'spread' it's ends.
        Hopefully you won't now have a chain that is too short...
        S.
          Sure that's a clip link?
          I don't think so.
            Yeah I've got the clip, just didn't photograph it.
            I just don't see how I'm supposed to get this thing to join together :S
              That's what I thought when I first saw it Desmo ... That chains looks like a chain that needs spreading not a clip.
                *giggle*
                you gotta grind off the end of a rivet and punch it out so you have rollers on both sides, as sprint says fingers crossed its not too short now
                i never count links btw, i install the full chain drape it over the sprockets to identify which link i need to cut- noting that they dont make chains for suzuki across' they make chains for motorcycles and its normal to have to trim to length.
                dont forget to put the O rings in
                Originally posted by Bendito
                  My kingdom for a grinder and nail punch!
                  I went to a bike shop and was told I need to take out one more rivet, so those outer plates come off. Now I just need to be able to get a roller and I'll be all set.
                  Thanks for the help guys
                    You have a heterosexual chain, you need a lesbian one i.e. one with female links on either end.
                    I use one of these but there are more industrial strength clamp style chain breakers available these days.
