Changing Brake Lever, HELP!!
  • Changing Brake Lever, HELP!!
    So I have just gone and bought some nice new shorty levers. Just went to change the brake lever, and behold as i removed the lever the piston behind the brake sprung out, no suprise here. However I cant physically push the lever hard enough to get the bolt back through as the piston is now solid.
    Any ideas short of draining the brakes??
    Holder of
    #013
    Ningaloo 2012 'Nekminnit' Smoking Ace
    Fuggin' BANG!!
    If has moved further out than normal and wont go back in because the brakes are activated, you WILL have to crack open a brake line. Its no big deal if you only let fluid out, just don't release the master cylinder plunger while the line is open.
      So just crack it at the lever or the caliper?? Or doesnt matter??
      Holder of
      #013
      Fuggin' BANG!!
        Caliper, it is more effective to bleed air out of the furtherest points if you accidently let some air in. Let air in at the top, and you may have to bleed everything if you get air in.
          Thanks for the assist mate.
          Holder of
          #013
          Fuggin' BANG!!
            Ok further to my last. Levers are now on however brake lights are permenantly on. Looking at the switch just inside and under the lever it doesnt seem that the button is getting pushed in (Assuming that is what turns the brake lights off). Starting to do my nut in now considering the brake lever didnt quite fit properly.
            Holder of
            #013
            Fuggin' BANG!!
              On some GSXR master cylinders there's a round insert, fitted into the lever, and the piston fits inside it. If this isn't lined up properly, the brakes will always be slightly on.
              You won't be able to ride it like that either, as the brakes will slowly lock themselves on as they get hotter.
              edit: What type of levers are you fitting?
              FTP
                Spend time comparing the old and new levers looking for how much changes they have made, and look for ways of adjusting it.
                You now know enough to change back at anytime
                  True that... I had to file one of the corners of the lever down to make it fit properly. They are a set of FPR performance ones. After filing down that corner they fit better but it just doesn't seem quite right.
                  Holder of
                  #013
                  Fuggin' BANG!!
