When I brake hard coming to the stop the front brakes start howling. It is still braking good and plenty of meat left on the pads. The bike is still under warranty. Is this normal or something wrong with the brakes? The bike is 2011 GSXR 750. It has done about 7000km, oem Brambo mono block and oem brake pads. I am concerned with the noise. The front brakes only howl when I brake hard to the stop and only start howling when the bike is coming to the stop.
Front brakes howl when under hard braking.
probably worth giving the rotors and pads a clean with some brake clean spray too
my front brakes sound like the wheel has fallen off and the forks are dragging on the ground but they still work so i haven't panicked yet.Do you remember the good old days before the internet?
Get some CRC Disc Brake Quiet and put some of it on the backs of the pads - it will absorb the vibration that creates the noise.
KTM enduro bikes have been making brake squeal noises for years - irritating. I put some of this stuff on the backs of the pads on my KTM and now the only squealing is coming from above the handlebar area.
Something like this, but don't get carried away with it like I did:
One owner. Only driven gently on Sundays. Sold to best offer. First to see will buy. Reward offered for safe return. Coming soon to a cinema near you. Available for a limited time only.
My waterbed broke this morning. Oh, I don't have a waterbed. Bugger.
Originally posted by Phildo View PostGet some CRC Disc Brake Quiet and put some of it on the backs of the pads - it will absorb the vibration that creates the noise.
Thanks for all the replies. I took the bike out for a quick spin and the breaks don't make the sound when they're cold. Strange...
I'm going to disassemble the pads, give it a good clean and apply brake quiet stuff on them and see how it goes.
Is this quite normal on other bikes to make that sound. The thing is it doesn't make any noise the whole time until coming to a dead stop. Its hard to describe it. Web search is inconclusive. Got whole bunch of answers such as warp discs, pads could be glazed etc.
It's a feature. It's like ABS, but less intrusive.“Crashing is shit for you, shit for the bike, shit for the mechanics and shit for the set-up,” Checa told me a while back. “It’s a signal that you are heading in the wrong direction. You want to win but crashing is the opposite. It’s like being in France when you want to go to England and when you crash you go to Spain. That way you’ll never get to England!” -- Carlos Checa
Originally posted by EL Echad View PostIs this quite normal on other bikes to make that sound. The thing is it doesn't make any noise the whole time until coming to a dead stop. Its hard to describe it. Web search is inconclusive. Got whole bunch of answers such as warp discs, pads could be glazed etc.
When you apply the brakes, vibrations develop. Those vibrations develop into sound waves. The red goo on the backs of the pads absorbs those vibrations, so no sound develops. Very simple solution.
As mentioned before, KTM front brakes have been doing it for years. In an enduro, you know when there's a KTM behind you by the brake squealing at every corner. No other brand of bike does that, so it will be the Brembo calipers that KTM use.
I was also getting some brake squeal noises out of the Magura front caliper that I put on my Aprilia SXV550. Same thing - put some of the CRC Disc Brake Quiet goo on the backs of the front pads and there's been no noise since.
You can pull the pads out and clean them, but that will only be temporary - as soon as you've used the brakes a few times there will be more brake dust accumulated.
With the Brembo calipers that I use on my taxi, I use some Bendix stuff on the ends of the pads. I've tried the same stuff on motorbike pads, but gave up on it and went back to the CRC stuff - the Bendix goo doesn't harden and washes off the pads when I wash the bike. Which means that brake squeal returns pretty quickly.
The CRC stuff semi-hardens into a soft rubber. Once you've applied it then you won't need to do so again.
Originally posted by EL Echad View PostWhen I brake hard coming to the stop the front brakes start howling. It is still braking good and plenty of meat left on the pads. The bike is still under warranty. Is this normal or something wrong with the brakes? The bike is 2011 GSXR 750. It has done about 7000km, oem Brambo mono block and oem brake pads. I am concerned with the noise. The front brakes only howl when I brake hard to the stop and only start howling when the bike is coming to the stop.
Can you post a pic of them ?
When you pull them out give them a scuff up with some sandpaper on a FLAT surface to clean them up. This usually works.
Its under warranty take it in for a look see...although knowing most dealers they will say... its your fault, its normal, they cant find anything wrong... then end up fucking something else up while lookingSmoke me a kipper...I'll be home in time for breakfast
Just to be safe - also check that there isnt any rocks stuck in the calipers, check that all the pistons are clean and not stuck and that the disc is not warped (get the bike shop to do it if its under warranty). If it isnt any of these they should be fine and if you want the noise to go away use the products mentioned above.
Fwiw I had my pads on my 250 start squealing - they had been wearing very unevenly (due to one of the pistons sticking) and one of the edges had worn down to the metal :o
