help with small lathe job
  • help with small lathe job
    hey all
    im hoping some one can help me, i need a 2 piece nylon bush turned out as pictured below or even if someone knows where to buy one, i have tried repco
    any help is appreciated
    cheers
    dimensions are
    ID 12.5mm
    OD 24mm
    Flange Diameter 30mm
    Flange Thickness 5mm
    Shaft Total Length 24mm
    NEVER KNOWS BEST
    If you can get a 100mm length of 30mm nylon rod down to South Lake for an hour one day early next week, I can help. There may be someone else a little closer though.
      Yeah, I'm a bit closer, live in Hillarys and have a workshop in Wangara.
      I don't have any nylon but heaps of Acetal or Polypropylene.
      What are the bushes for?
        thanx for the offer Captain
        Which one would be harder?
        It's to replace a rubber bush on an exhaust mount as I want to limit the amount of movement of my shortened can without using an exhaust bracket if that makes sense
        NEVER KNOWS BEST
          Acetal is harder but the existing rubber is there to reduce vibration.
          Just to clarify, the two piece bush is actually two identical bushes?
            SIMPLE english... old fart
            we'es just a youngun"
              Sorry [MENTION=25224]GSX IN SHED[/MENTION], let me explain...
              Rattly hot bit at the arse end of motorthingy more noisysome rigidnotferme
              Itch to thurownthough, appytohelp pissnotwithstanding but tiddly I po po rightnow so imado it Munday sober as.
              Bushes R Us. No Brazilians here mate.
                Oi, [MENTION=28240]Old frt[/MENTION], looks like Jamathi's been at your computer.
                  Time to fess up, we are the same person...
                    sorry if this gets confusing, looking at what i wrote now i should have said: if they are identical then the shaft length would 12mm each, when put together total shaft length is 24mm
                    but being identicle doesnt matter as long as the total shaft length is 24mm
                    im not worried too much about vibration at the moment
                    im hoping that this bush along with a new gasket/collar where the exhaust meets the middle section of pipe will lessen the available moment of the can
                    NEVER KNOWS BEST
                      [MENTION=33106]orazzal[/MENTION] I'll knock a couple up for you on Monday.
                      You can pick them up Bus hours in Wangara or Hillarys anytime.
                        Thanks I'll send u a PM soon
                        NEVER KNOWS BEST
