Hello,
Today I was on the Kwinana Freeway and everything was fine until my rear brake lost all pressure. I could rest my foot on the rear brake lever and it would go all the way down. I believe I may have had air in my system causing pressure loss(?).
I promptly pulled off at the next exit but shortly after my rear brake was back to normal. It worked fine and was very responsive.
The bike is 2nd hand but the previous owner changed new brake pads.
What is the problem? I've read I may need to 'bleed' my brake system?
Also, If the brake went back to normal after, should I still worry about it?
Any advice what I should do?
