makes no mention though of the clutch issue: many car oils have PTFE or similar additives as "friction-reducers", which is not good for motorcycle wet clutches where you want them to grip...
"No machine has a soul until a man shares his own with it."
However, the prices on that page look far worse than what we deal with here.
I got honda GN4 oil and filter for my 600rr the other day for about 50 bucks or so, which is on par with the typical price you'd pay for some castrol semi-synth for the cage - and I know it's the correct viscosity, etc for the application...
If you've got a bike with a dry clutch, i say go for it - but if it's a wet clutch you'll need to make sure the oil will work properly with that...
This is an issue I have looked into a lot over the last 16 years of riding.
For 99& of the use there is NO difference between car, bike or light diesel oil. You can run all 3 in your bike. In fact if you have a look at a lot of oils now they even say they can be used for all 3.
I have run, car, diesel and bike oil in my bike. If a 270kg bike with a rider just as heavy can do it without the clutch slipping than its fine.
However....
There are SOME car oils (mostly 30W) that have friction modifiers in them. Castrol is a good one for that. But they all let you know. Sometime they call it energy effecient or fuel saving or some other crap.
Diesel is actually good to run in a bike as there are no additives that could stuff up a wet clutch. The only diesel oils to avoid are high ash content ones designed for Roadtrains etc.
When I pull my finger out I'll see if I can dig up the links I have including one site in the US where Shell itself says Rotella is fine for bikes.
There are no super-duper magical ingredients in bike oils (that aren't in car or diesel) to make them any better. Its just clever marketing.
As long as it has the correct API SG/SL rating etc. you are fine.
Ive run car oil before, the only reason i use bike oils now is because i get when im at the bike shop buying a filter. I ran penzoil GT performance in a CBR600, did 105000k's on it with no dramas at all. Stripped it down at 70k, mainly to reseat the valves, thought i might as well check it all out while its apart, all bearings were fine, bores and rings good, no exessive wear anywhere and it was the cleanest motor inside i have pulled apart. As others have said, stay away from oils with friction modifiers in them, will stuff a wet clutch
This was before Tyson ran the bike on car oil. When it blew its load, we just scavenged some car oil from around the traps, went out and did the rest of the demos.
[ame="http://www.youtube.com/watch?v=cNIuKuUBgvw"]YouTube - Firebusa at Hoonavation[/ame]
