If you can't find what you're after, have a look at the places online that do custom mouse pads using wetsuit rubber. You'll have to use contact adhesive to attach them etc, but it should be fine.
If you have no luck there, even, I have access to a thermal transfer flat press which will take your design and (probably) get it onto an offcut of wetsuit rubber.
These are kind of last resorts though - if someone actually does this stuff as a business go that way first!
1. Buy clear tank pad
2. print design on paper with adhesive backing
3. apply clear tank pad over design
4. trim around pad with a sharp knife
5. use paper's adhesive to adhere to tank
