Anyone for running red lights??? B-)
has that happened to anyone? having the sensors not pick you up?
I know it happens at the intersection of railway pde and grand prom when heading south down railway pde.
Also the intersection of St Georges and Milligan Street in the city if sitting on Milligan and heading towards the entertainment centre.Red meat isn't bad for you. Fuzzy green meat is bad for you.
Light Sensors
Having problems with lights not picking up the bike?
Have a look at the ground at most intersections around town (where the problem is most experienced) and you'll see a new sensor that has been put in. Its designed to pick up cyclists, so it will obviously pick up the motorbike.
The sensor is painted white (broken squares in a straight line and a picture of a bicycle).
Biggest problem is that most seem to have been put too close to the grease strip.
Re: Light Sensors
Every one I have seen is smack on the dirtiest, greasiest ugliest section of the grease strip.
Now you would think someone from Main Roads might have actually consulted a bike rider or two and found at that we dont stop on that section of the lights!
Snappas.
When did you last try it?
Re: Light Sensors
Snappas.
However our crotch rockets which seem to be comprised of mostly alloy and plastics are not detected until they sit pretty much right on top of the sensor. "The location of the sensor?" i hear u ask. Right under that picture of the pushy.
Thats the way they have always been installed. Its not a case of "new ones being installed to pick up pushies and us". The councils are just marking them in now because of complaints.
Trust me i used to work for stork electrical installing the f***ing things! U have no idea how much fun it is to sit there all day and w8 for a motorcycle to stop at the sensor u just put in to see if its pickin em up properly. Most of the time we'd give up after 15 mins. Hense some dont work...
Hey i got better things to do than sit on the side of the road and suck carbon-monoxide all day...
Re: Light Sensors
Snappas.
Green Light Signal Tripper
The Green Light Signal Tripper allows motorcycles to trigger turning lane lights, apartment complex gates, and any other magnetically controlled traffic control system. How? Very simple - click to read more!
www.tricktape.com
Re: Sensors
So why the fuck have they been put smack bang in the middle of the grease strip???
If you ride a bike why didn't you explain the dilemmas in stopping on the that spot when they asked you to install them???
its the best spot for pickin up all types of vehicles. so if u want the lights to change. sit in the grease strip.
