The only complaint i have about the new busa is that the side stand doesnt seem to have a flat enough area on the base and that it really only sits at tad past 90 degrees.
If you put the stand down when even moving forward the smallest amount or if you dont make sure it is all the way forward and on perfectly even ground it has a tendency to want to go back up.
Did it this morning and almost damaged my new bike.
Is there aftermarket side stand and did the old busas have the same sort of stand if so was there a remedy
