Question: power to weight ratio....
  • Question: power to weight ratio....
    something I really don't understand, and hoping that some of you have the answer to the question.
    ok here is the one million dollar question for all the riders.
    how can a bike have more power to weight ratio then the other bike, but lower horse power?
    for example the hyosung 650gt has 0.407 power to weight
    the yamaha r6 has 0.27 power to weight
    HOWEVER
    the hyosung has around 80 horse power
    the yamaha r6 has 110 horse power
    Because it also has a much lower weight. Power to weight is how much power it produces in relation to each kilogram of weight the bike has eg 98 CBR600 105hp - 184kg = power-to-weight ratio of 0.57 (105/184). Not really a million dollar question, simple maths.
    Plus, you've done the math wrong - Hyosung = less power, more weight = lower power to weight ratio.
    Using your examples:- GT650R 208kg, 80hp = 0.38 R6 185kg 110hp = 0.59
    The closer to 1 the better.
    Nulla Tenaci Invia Est Via
    For The Tenacious, No Road Is Impassable
      And don't forget to factor the rider's weight into the equation.
      "Live Long and Prosper"
      Bayswater Martial Arts and Yoga Centre
        my question was how can one bike have higher power to weight, then the other but lower horse power
          Isn't it generally held that if youre comparing the power to weight of vehicles you assume rider weight to be the same so that the results are comparable?
          Originally posted by Amac
          suck me on the hat you mole fucker, steroid affected me cock
            Lower weight
              Less weight - see the formula above. Power divided by weight.
                Simple - the bike has less weight.
                  And your example is flawed because it's wrong. A GT650R does not have a better power to weight ratio than a R6 BECAUSE it weighs more, and has less power.
                    i get what you saying
                    so shouldnt the yamaha have more power to weight then the hyosung? but all the specs says that hyosung has more power to weight then the yamaha.
                    still bit confusing
                      Yes, but you have to factor in a 'standard-sized' rider - eg. 75kg added to each bike's wet (not dry) weight.
                        link to the specs please.
                          dont worry i get it now~ some of the specs i have been looking at are wrong!
                          thank you xsnoiz, thank you master !
                            Your math is wrong. As above, using your examples:-
                            The Hyosung produces 0.38hp per kg
                            The Yamaha produces 0.59hp per kg
                            Understand?
                              ahh, I see what you mean now. ^_^
