Fuel Gauge 2007 Hyosung Aquila Gv250
  • Fuel Gauge 2007 Hyosung Aquila Gv250
    G'day Motorcycle Gurus,
    I've been looking through the "how to's" and I'm still yet to find a solution to my little issue.
    It appears the fuel gauge on my motorcycle (2007 Hyosung Aquila GV250) is stuck on "full". It's not really a big issue, because I make sure I fill up every 200-250km, but as some-what of a perfectionist, it's annoying me.
    Now, I'm aware it could be one of three things,
    1. The gauge itself (This seems likely, seeing as it sticks on 'full' when the ignition is off)
    2. The wiring.
    3. The sender.
    I'm mainly after some advice on how to repair/check these things, I've been all over google and found nothing helpful, yet... Maybe one of you have had the same issue and may have some helpful advice for me?
    Any help would be greatly appreciated.
    Thanks, people!
    - Tom
    silly point but have you tried gently tapping it ?
    Master of the missed signals
      also does your bike use a float, or is it electronics?
        Try having a look on korider.com and see if anyone there has had the same problem??
        LET’S BE STRAIGHT HERE, GENTLEFOLK. AT THE DISTINGUISHED GENTLEMAN’S RIDE (DGR), WE RIDE FOR A PURPOSE.
        Our focus is on gentlemen who have been dealt a tough hand in life. In particular, we raise funds for research into prostate cancer as part of our mission to support men’s health.
        With your support, DGR is aiming to raise $5 Million USD this year to assist in finding a cure for a disease that kills 1300 men a day worldwide.
        Donations via: www.gentlemansride.com/fundraiser/canam
          If you can disconnect the wiring near the gauge you could then check continuity and resistance of the wiring and level mechanism with an empty and full tank...
          This will let you know if you have a jammed level mechanism as the resistance should change from empty to full...
          If that checks out then you can assume it's the guage and go from there...
            Thanks for the suggestions, guys. I have a day off tomorrow and will be performing a full maintainence (including the fuel gauge). Will let you know how it turns out.
            Cheeerrrrssssss
              Ended up taking the gauge apart, and unsticking the needle. Just a little of WD40, and the problems solved.
              Cheers, guys
                I've only owned my GV250 for a couple of months and thought I had a problem gauge (always on full) but after reading some threads found that that gauge needle does not come down until you're almost ready for reserve. It does work - but in that cockeyed way. Go figure... But, then it seems you've fixed yours with WD40 - good show!
                  Hyosung GV 250
                  Cheers, guys
                  Hi Mate,
                  Can you please provide me with the steps on removing the fuel gauge if you could still remember? I am having the same issue.
                  Thanks.
