Led conversion
  • Led conversion
    Hi all
    I have a 2002 bike that I want to put led indicators on.
    I have the idicators and an LED relay..I have installed these and they do not flash with the switch.Any useful help would be greatly appreciated :o
    :o
    Living the dream!!
    While I don't know the technical term for it, LEDs only work with the positive and negative in a certain direction.
    Ie. Try swapping the positive wire with the negative.
      Diode.
      In sterquiliniis invenitur.
        narva 68249BL LED relay 2 pin works well on my 04 R1.......from Repco $36
          Motorcycle Scooter 12V Flasher Relay Led Indicator Relay(2pcs) [GMOPED-016] - $9.88 : Chinaatvpart.com, The Art of E-commerce
          These ones are good too for $10. (not including postage of course) and are good if you need something with a rubber mount for older bikes that don't have a fusebox under the seat or whereever to mount the things.
            Good one thanks......but wanted a quicker result somehow???......turned out be a cut wire on the loom where the left hand side fan cut in...anyway all sorted now....cheers
