How to fix up a trailer with rust spots?
  • #16
    Originally posted by 51 New West View Post
    A friend of mine had his old 5x8 re-floored by Corrective Services at Canning Vale Prison. Good job, good price.
    Hmm thanks I'll check out how much, I like doing these projects though
    • #17
      Sanded
      Kill rust-ed
      Painted
      Sheet steel welded on front half after pic was taken
      Total cost about $150
      • #18
        Originally posted by 98kellrs View Post
        Nah, you'll struggle to weld aluminium to steel ferrous and non-ferrous metals don't like to party. I'd flap disc the rust off the steel, paint it in some cheap anti-rust paint to prevent flash rusting from appearing and then just bolt/rivet the aluminium straight over the top. 2mm tread plate should be pretty cheap. I'm not a fan of steel trays due to rusting, so I try to line anything I have that's steel.
        **Disclaimer: I'm far from an expert; there's probably a better way of doing it. Just depends on how much money/effort you wanna put in.
        Sorry boys you can't weld ally to steel ,I would use 2.1 checker plate steel and either cut old floor sheet out or you can just lay new sheet over top of old one not recommended due to rust just carrying on underneath new floor ,my qualifications for this advice boilermaker / 1st class welder ,welding supervisor cert 10 ,welding inspector sw1 and as1796 3e .
        • #19
          Originally posted by Carbon14 View Post
          Sanded
          Kill rust-ed
          Painted
          What did you sand that with?
          In sterquiliniis invenitur.
          • #20
            Floppy Sand disk on a grinder
            • #21
              cool good job
              K1 Bandit 1200S,
