Rust in Fuel Tank, New tank ? Resin repairs ?
  • #16
    What about this stuff
    http://rustsolutions.com.au/collecti...st-remover-gel
    Also I had a blocked breather hose for the tank and fuel expanded through the key hole and has corroded/etched it any ways to remove?
    • #17
      http://www.bunnings.com.au/white-kni...erter_p1565407
      ^this is $14 a bit cheaper. you wont need much to cover a square inch or two, you should be able to just brush it on lightly.
      Originally posted by Bendito
      • #18
        What time does potato open?
        • #19
          now
          dianella 93703770
          • #20
            After ~ 3 minutes on high in a microwave
            Originally posted by Phildo
            Originally posted by filbert
            • #21
              Lucky i got mr potato to fix as there was considerable amount of rust underneath the cap assemble once removed.
              Pretty sad considering the bike sits mostly in the shed
              • #22
                Strap your tank to a cement mixer. Put in sand and gravel. Run it for a while until the rust is gone and then blow it out and finally rinse it with a solvent.
                Then slosh a two pack sealer around the inside.
