Removing oil/grease stain from concrete driveway?
  • #16
    Slight segue but will any of the above work for cum stains on curtains?
    Originally posted by Phildo
    Originally posted by filbert
    • #17
      Wot, like "Beef Curtains?"
      • #18
        i doubt CLR would work cause its for calcium lime and rust but a good higher flash solvent degreaser might? some of those really greasy low flash cheap degreaser dont dry and would probably just disperse it more into the slab. then hit it quick with a real good high pressure washer.
        i've found CLR to be a bit namby pamby even neat on just about anything really....
        I cant help it if your perceptions don't match my reality
        • #19
          scissors mate! hey will be posting a ride soon you likely to prefer working?
          • #20
            I'm always up for a ride, just depends on shifts
            • #21
              I've successfly used kero to clean up oil stains in the garage. But wouldn't recommand for doing large areas due to needing to scrub it.
              2013 Honda CBR500r
              1996 Nissan Stagea
              1979 Ford Escort
              • #22
                I use truck wash with abit of windex, voila.
                • #23
                  Brakleen to lift, degreaser to flush...
                  • #24
                    I had my garage coated by CBH Coatings in a decorative finish. I can leave oil on it for pretty much as long as I like and it wipes straight off.
                    Click Link for My Bikes:
                    Aprilia RS250
                    1985 GSXR750 "Slabbie"
                    • #25
                      Commercial concrete degreaser like ACT Concrete Cleaner and Degreaser is one of the best methods in this situation that can help in removing larger stains on your concrete driveway. These degreasers are a concentrated alkaline soap that loosens the oil from the concrete to permit easier removal and Poultice could be a great method for smaller stubborn stains.
