99 GPX 250 with a 08'- ninja 250 engine install
  • 99 GPX 250 with a 08'- ninja 250 engine install
    Hiya
    I recently decided I miss my old GPX. 2 hours later I had bought two. One unregistered parts bike, the other registered as an unfinished project, which was almost complete, less a few things.
    Has anyone else done this?
    I've fitted the carb from the 250 parts bike (original gpx carb) onto the new engine but a few things don't match up.
    Do I need to get a carb matched to the engine?
    And there's one plug that has an old connector on the original harness but the new engine side of the plug is different- anyone know which point goes where?
    Can I fit the old GPX pipes to the new ninja engine if they fit?
    Pics below of each bit that's confusing me.
    PS- I also have a 250 ninja track bike I will butcher for parts if need be.
    Thanks for the help!
    Sent from my Nokia 3 using Tapacrap
    And I also need to figure out how to make a custom coolant pipe from the thermostat to the top end.... Any suggestions?
