Has anyone figured out what this mode switch actually does?
The manual is pretty light on, says something like A mode is aggressive sport performance, STD is full sporty performance and B helps you ride slow.
The manual's description kind of tells you the aim of the modes but not what is going on.
I originally assumed A mode was like a quick action throttle, STD is standard throttle and B a slow action throttle. but i am not sure its that simple.
i am starting to think that A mode is not a linear throttle map, but more like 50% throttle is in the first 10% of the range, and the last 50% throttle is in the next 50%.. making it like a 2/3 throttle thats on the piss and really only suitable for high RPM use.
STD mode may give full performance, but does it have some kind of signal smoothing that stops you from cracking it to carry the front over rises? also does STD limit the available throttle depending on gear?
imho B mode should be inbetween A and STD, like a proper linear 3/4 throttle no signal smoothing.
