Yamaha AC voltage lighting circuit
  • Yamaha AC voltage lighting circuit
    Hi All,
    Need some advice on the lighting circuit for a wr250f.
    Im going to install a brighter headlight and want to wire in a relay directly from the battery to maximise the current to the headlight.....the problem is the lighting ciruit is AC voltage, not DC like most cars.
    How do i install a relay to the headlight when all the circuitry is AC voltage and keep the functionality of the hi/lo beam switch?
    Thanks, Steve.
    Another issue im having at the moment is the headlight and taillight go dim when the indicators are on....does anyone know how to fix this issue?
