installed GYTR frame sliders... engine bolt torque question.
  • installed GYTR frame sliders... engine bolt torque question.
    Hey Guys, Did a search but couldn't find anything... so...
    I just installed some GYTR Frame sliders and the manual said to torque the bolts to 70Nm. just wondering if that is ok because 70 Nm is pretty high, I am also aware that other frameslider companies says to not torque over 40 Nm...
    Also I torqued the engine bolts to 65 Nm just in case... is there any problems with under torque the bolts at all?
    Thanks in advance
    no . its alright . just make sure its tight enough . dont worry about making it really tight . 65 ok
      just found out there is a rattle sound coming from the right hand frame slider when the bike is in neutral, pulled the clutch in all the way. The sound goes away when I release the clutch, or put the bike in gear with clutch pulled in.
      werid... :S any one would know why?
