Mercury for balance gauges
  • Mercury for balance gauges
    Anyone know where I can get mercury for my balance gauges??
    MM
    you'll be lucky Marty due to how poisonous it is, my set uses as blue fluid, is this for a home made set??
    1:Which way do I go
    2:Whats the lap record.
      Na got given a set LOL what other fluid will do ??
      MM
        Just did a search and found this, what brand is yours MM? might be outta luck replacing mercury.
        Syncpro Manometer Fluid Refill
        Manometer fluid refill for 08-0411 SyncPRO Carb Tuner
        Non-toxic
        Mercury free
        Motion Pro blue color
        SyncPro Manometer Fluid Refill does NOT work with older Motion Pro mercury carburetor synchronizers
        NOTE:
        SyncPRO™ manometer fluid cannot replace mercury
        and vice-versa
        1:Which way do I go
          Looks like I need a new one or a Geo to get me aome off the ground up North
          MM
            Can vouch for the motion pro Sync Pro one, very nice bit of kit, if you need to borrow one in a hurry let me know.
            1:Which way do I go
              You can try refilling, but mercury is denser than what is used in the newer ones (which I think is alcohol), so you are more likely to suck it into the carbies. Depends on how exactly it works and how much you lift the mercury, but as a guide 10mm mercury = 135mm H20, so if you were lifting the mercury 10mm and refilled with water you would lift the water 135mm with the same vacuum.
              Maybe you could try something like a thick oil which might not rise as quickly due to its viscosity?
              #166
              Bernie says "think before you drive bribe"
                Pretty sure sigma chemicals and rowe scientific in balcatta have it
                Originally posted by Bendito
                  try the chemist. used to be able to get it from there. very cool stuff, very dangerous
                    Dwyer instruments will sell you mercury for manometers
