So, before I get started, I know this is a long shot and I should probably just take the bike to Kamahl and get him to ride it. This may well end up happening.
Before I do though, just in case this tweaks someone's memory, I'm hoping for a clue here.
A while ago (10,000km or so?) I replaced the timing chain and clutch plates (EBC kevlars) amongst other things. I also ripped out the TRE I installed ages ago. The engine became a bad mofo again after getting into a bit of a tired grandad rut. Annoying because from 2500 - 3500 RPM it would hunt and surge, and burbled popped and BANGed the zorst on overrun despite a very lean map on the PCIII. Annoying because the clutch is now really heavy and grabs until it gets some oil through it - clutch lever fully in and the bike will still take off forward if I start it in 1st when it's cold.
Still, plenty of power, really good fuel efficiency, a little bit bitey and lacking smoothness but otherwise a huge improvement.
Fast forward a few months. The busa had a bit of a hissy fit one night last week.
After getting a fresh tank of juice and riding for an hour or so, then getting a bit of air off a couple of speed humps (they are such good fun) and then some more fairly sedate riding I may or may not have attempted a little powpow 1st gear wheelie. It came up, revs started climbing, got to something well short of the limiter and I experienced a lurching lack of power combined with a God-awful "clack - clack - bump" noise from somewhere under me. Every time, every gear I powered out for the rest of the night the bike would hesitate and generally be reluctant.
I got home and discovered a woefully loose chain
which I've since tightened, I'm thinking from the sudden reverse spike in torque from an airborne free wheeling rear wheel to suddenly back to relatively low speeds on landing. Meh. Is okay now.
But that surging and shit is still there as always from 2500-3500 and, now, from about 4000RPM up a hesitancy comes in. Almost like it's misfiring or only partly misfiring, but the engine still sounds pretty smooth. Almost like you're hitting tight/not tight bits in the chain but it's a little more random and is definitely related to RPM and throttle - the more I ask, the more it sulks.
This ringing any bells?
Otherwise my next steps are to check the timing with a light, check the valve clearances again, change the plugs (just in case, they probably have 20,000 on them), change the fuel and flush the tank and pump/filter, detergent soak the K&N filter and then, finally, spit the dummy and throw it at Kamahl.
