Dropped my bike and bent the brake lever. Found this great vid: GS500 Brake Lever Replacement - YouTube
I tried to check if the brakes still works or not by trying to take off with the brakes still on, and it seems like the brakes aren't engaging.
Just wanted to know if there are any other bits and bobs inside the slot that may be fucked? Or most likely if the lever is replaced and it'll be fine?
I've also noticed the following tubes that may / may not be fucked as a result of the drop...the second one on the image was leaking a tiny bit of fuel.
ImageShack® - Online Photo and Video Hosting
Are these normal? Don't see how the drop could have resulted in those two tubes tearing...
Also ...thoughts on a helmet hitting the ground ? Literally from standing and seemingly light tap. I know its pretty much a write-off if your head is inside but was wondering if there is a threshold as I was pretty much stationary. Helmet was a shark s900c.
