Hey guys,
So im trying to bleed my new brake setup and its basically giving me the shits. I have bled a fair bit of fluid through, not seeing any bubbles. But the pistons are moving in and out slowly (takes about 5 seconds to grab and the same to release from the rotor) and the lever will still pull in all the way if you hold it.
Is this a sign of air still in the system somewhere? I have bled the master cylinder first then the caliper. I have also put thread tape over the nipple threads as I was sucking air in through there. Any ideas or anyone willing to lend a hand?
Cheers.
Cheers.
