Aftermath of brake failure
  • Aftermath of brake failure
    After bringing my car beyond what it had been designed for brake wise on the weekend with brakes failing completely I wonder now, why I had the reservoir spilling over and air in the system once the brakes had cooled down again. Only had the brakes flushed with fresh DOT 4 too. The front discs were the ones that had gotten hot. The rear drums were acceptable.
    My limited understanding suggests there should have been water vapor bubbles. But don´t they collapse back to water and get nicely mixed up again and the brakes are just fine afterwards again? Or does fresh brake fluid cook to something else that does not go into its original state and therefor bleeding was necessary?
    Who did the brake flush? Sounds like a proper job NOT.
      Sounds like you got billed for a flush and one wasn't done.
        Nah I attended the flushing and it was a job well done. Too much bad experience in the past so I insist on watching. If they are not cool with that, I am not interested either. Race track and the tenth time slowing from 120 to 50 with smoking pads and all that will do that to a women´s car. DOT 4 is only the lowest temperature stuff too. So it was not unexpected.
        But when ever I had brakes failing I did not have to bleed the brakes again and that made me wonder.
          There is no such thing as water mixing nicely with brake fluid... water is brake fluid's worst enemy... so much in fact I don't even bleed my lines on a rainy or humid day.
          also more reading here;
          Brake Fluid
          Since brake fluid is hydroscopic it will draw moisture into itself from the atmosphere, one of the reason they always tell you to use fluid from a sealed container, what typically happens is that it is the absorbed water that boils at a much lower temperature than the fluid... then you no longer have brakes.
            Brake Fluid
            Hygroscopic
              WTR1S brake fluid is intended to absorb water to keep from rusting lines out or droplets forming that reduce efficiency, a saturated solution still has a higher boiling point than a water droplet on its own within the line.
              Once evaporation temp is reached the water or water/brake fluid solution turns to gas and a bubble is formed, the only way for that bubble to reabsorb into the fluid is pressure to compress it, if you pumped your brakes enough times the bubbles would all but disappear, but they would reform just as quickly under working conditions again.
              Maybe try some super DOT4 or DOT5.1 fluid for the higher boiling points, even the act of heating and cooling between brake points can increase the moisture absorption as it's not a sealed system, the higher the "wet" boiling point the greater the punishment your brakes will take before a repeat performance.
                You can flush brake yourself easily enough. It's even a one-person job that you can do at home if you get some speed bleeders.
                Brake fluid tester: Australian Ford Forums
                Speed bleeders and brake fluid flushing: Australian Ford Forums
                For brake fluid, I use PBR Super Dot 4. I get it cheaper from (speak to John):
                MTQ Engine Systems (Aust) Pty Ltd
                63 Beringarra Ave
                Malaga WA 6090
                (08) 9203 1000
                What car do you have? What brake pads are you using?
                I use Hawk Performance ceramic pads. They're not cheap, but I can belt the crap out of them and they handle the heat.
                Hawk Performance Brake Pads: Race Proven, Street Legal
                One owner. Only driven gently on Sundays. Sold to best offer. First to see will buy. Reward offered for safe return. Coming soon to a cinema near you. Available for a limited time only.
                My waterbed broke this morning. Oh, I don't have a waterbed. Bugger.
                  Originally posted by agrid View Post
                  Hygroscopic
                  Dammit. Must proof read better. Quite right ^^^WHS
                    Another quirk of our dumbarse language. I bet the Germans wouldn't do something like that.
                      I am ashamed.... "hygroskopisch"
                        Ha! I looked too. I thought they would have Hurbengurbenschtinkenschtonkengurblemeister for "fluid that readily attracts water from the atmosphere".
                          English doesn't borrow from other languages. English follows other languages into dark alleys, beats them up for their words and goes through their pockets for loose grammar.
                          —Raina Bird
                          Mistakes like that are just a case of borrowing from different languages at different times.
