What would be the best way to clean the chain? I currently use Belray chain lube. the white one that does not fling off. i have been happy with it but it makes the chain all white if you over do it. I also have some brown stuff on the chain. No it is not rust but seems to be clinging to the chain lube. that is why i am asking if you guys clean ya chains.
Do you guys clean you chain every so often or do you just pack the chain with lube? Also how long do chains normally last for if they are looked after correctly?
Masda74
Masda74
