A while ago I mentioned I made a bike stand, but I forgot to post the plans.
Here they are:
Made for a TRX850, but you can easily adjust the dimensions as you need to.
Note: The stand is fairly compact but I found it is still reasonably easy to push it down with one hand, holding the bike with the other.
It gives the rear wheel about 50mm clearance of the ground, if you reduced this to say 20mm to make it easier to lift it up.
Feel free to dnld and have fun making it.
Oh yeah, it's 20mm SHS (Square Tube).
The bolts are because it was easier than geting rod, easier to weld in place too.
*Disclaimer* If you fall off trying to do a wheelie-dude / christ-air / leap-of-faith, me not responsible.........but you shoes! Post photo's!
Here they are:
