Hey All I need some advice on how to get reid of a squeaking rwar brake. I had my reap pads changed at my last service and now they are squeaking. Any suggestions on how I can stop the noise.
Squeaking Rear Brake
Originally posted by Desmogod View PostTake the pads out, lightly buff the faces and leading edges, then reinstall them with a very thin coat of copper grease on the piston side only.
DO NOT get any on the friction side or the brake rotor.
Kthxbai.
Originally posted by Jonchilds View PostRTV gasket maker works well on the back of the pads too if you've got any of that handy.
Meh, I'm not gonna argue.
Shmeh.
Some of the the stop-squeal pastes you can buy from Auto1 or Repco is basically an RTV product, so I don't see the difference.
I've certainly seen mechanics use the high temp RTV on pads for a car before as it stops the pads sticking against the discs when the pistons retract.
