The lights on my bike are not working ( both Low and high beam ), the main light looks dark as if it may have blown, will this stop the high beam from working
lights not working
Could be any number of things sounds like one is a dual element jobby H4 60 high 55 low (the H4 common car globe h7 isn't exactly rare etheir) usally if the low beam goes the high beam contiunes to work. However do any of the other lights work instrument tail etc etc. If so its probally the globes or depending ont he age of the bike and if you ride all weather it might be road grime in the switch gear (common problem on Honda's) check you fuses while you're at it. When installing Halogen bulbs be very sure not to directly handle the glass the residue off your finger will create hot spots and it will nuke itself again in pretty short order.
If you post a technical problem include the year model and brand of bike. Otherwise the answers tend to be very general.Harvey community radio has a motorcycling show listen over the web here www.harveycommunityradio.com.au ,Facebook here http://www.facebook.com/pages/The-Mo...34691323302991 yes I am the goose that hosts it.
Id say it will only have one fuse for all lights,therefor your fuse is most likley fine and the bulb/bulbs have gone, because youve got dash and tail lights."YOU CAN TEACH A FAST RIDER TO STOP CRASHING,BUT YOU CANT TEACH A SLOW RIDER TOO RIDE FAST." Mick Doohan
Its likely however because the headlights draw high current they tend to be on a seperate circuit to everything else but it really depends on the manufacturer. The fact the other lights are working suggests a bulb but there are other things it could be.Harvey community radio has a motorcycling show listen over the web here www.harveycommunityradio.com.au ,Facebook here http://www.facebook.com/pages/The-Mo...34691323302991 yes I am the goose that hosts it.
I'd try cleaning our the switch blocks with contact cleaner and the contacts for the relays. You still havn't informed us what bike it is which is not very helpful for us to help you.Harvey community radio has a motorcycling show listen over the web here www.harveycommunityradio.com.au ,Facebook here http://www.facebook.com/pages/The-Mo...34691323302991 yes I am the goose that hosts it.
