Oil light on, not oil level. 03 zx12r
  • Oil light on, not oil level. 03 zx12r
    oil light is on, oil pump sounds like it is alive, oil is fine and at a normal level.
    but oil light wont turn off.
    bike rides fine.
    Does your bike have a seperate oil pump (that your hearing)? I wouldnt have thought so??
    Check the Kawasaki forums if you have no joy here - will be a oil pressure, or oil level switch. Not sure on that model.
    Could just be a faulty switch that needs replacing.
      The oil light is a pressure switch, not a level switch (like the one in your fuel tank).
      I'd be checking the switch first, and making sure it's not something simple like a loose wire, then the actual switch itself, and after that, check the oil pump.
      edit: My bad, I assumed all oil warning lights were pressure related
      FTP
        The switch is located just forward of the alternator cover. Will be a single blue and red wire and is only secured with a philips head screw behind the rubber boot. I would be starting there, then checking the wire for continuity.
        The ZX12 doesnt carry a lot of oil, so if the pressure is down you will damage number 3 or 4 bearing in quick time. I got some cranks and cases in my shed to prove that. If in doubt dont ride it.
          ^only know it was riding fine as i got down the road, realised the light was on and went straight back home.
          will give that a shot tomorrow.
          cheers for help kids.
            update: fairings off..
            poked around a bit, all connections were fine.
            put everything back together.
            oil light off.
            2 hours later, took it for a ride.. oil light still off.
            weird.
              oil light off.
              weird.
              Let us know if it happens again. Poking around the connections may have fixed a dodgy one. Glad its all ok and on the road though.
                weird.
                Thats those pesky Kawasaki engineers keepin' ya on your toes
