I need a new discs/set of discs for the front of the Bird as one is warped or bent and causing pulsing when hard on brakes.
I'm fairly limited as far as funds go, so I've narrowed it down to two:
EBC Pro-Lite ($189US each)
or
ChainGang Discs ($240AUD using existing carriers)
The EBC rotors are low-carbon steel with the 'bird swing' drilled pattern, whilst the ChainGang ones use a carbon wear plate and have a slotted pattern.
I don't race, so the choice isn't *that* important, but I'd like to know the differences between the two are, particularly for an alll weather rider who doesn't want his discs potentially rusting away (in contrast with stainless steel ones on there now).
or
