Wheel polish
  • Wheel polish
    Hi. I want to get my rims polished. I currently have an mt09 with blue rims. The problem is in some light they look purple and hideous. Also people accuse me of being a freo supporter.
    I want to get the outer part of the wheel polished up but I don’t know who to talk to about it or how it even gets done. Anyone had it done in the past?
    You may only view thumbnails in this gallery. This gallery has 1 photos.
    The bitter taste of poor quality last long after the sweetness of cheapness has gone
    Hi. your in luck mate, I think I could help you on this one. this one time.................................. a while back..............i had polished rims on my murdercycle........................ and I changed them to a hideous purple because people didn't know i was a docker supporter.
    also this is how you attach a picture :
    your welcome !
    hope that helps.
    I cant help it if your perceptions don't match my reality
      You could do like I did last night leaving the Optus stadium when I zipped me bike jacket up over my purple shirt.
      Rattlecan black would do the same thing.
      The crux of the biscuit is the apostrophe.
        The colour is candy apple blue...some Yamahahaha riders call it blurple because of the aformentined confusion in some light...The paint comes off fairly easilly...I found out when I dropped the rear caliper on the wheel when removing it to fit a new tyre causing me to have to get a rattle can from Malaga. I would imagine a bit of elbow grease and some fine wet and dry will get the results you want.
          Maybe you should swap rims, you get a pristine one and as he want's to remove the purple anyway he's part way there
          Originally posted by Phildo
          Originally posted by filbert
            Mine has a fairly new Bridgstone on it....dont want the crappy Dunlop OEM rubbish thankyou!
              Mine are brand new bridgstones. Thanks anyway.
                Interested to here if anyone can genuinely help biscuits out here with a recommended wheel polishing service. I have an alloy rim that I wouldn't mind getting polished and would like to hear about peoples experiences. As I write this though it occurs to me it has probably been commented on numerous times in other threads over the years.
                The body is weak and needs to be punished!
                  There are numerous threads on PSB, however I couldn't get old results on PSB's search feature. A google search sorta worked: Click here
                  Wheelgleam in Osborne Park is good, theny polished some old aluminium Ducati racebike parts- came up like a mirror
                  9444 8338
                  22 McDonald St West
                  Osborne Park WA 6017
                  Refleks Metal Polishing (used to be in Malaga, they are in Bayswater now)
                  Ph: 9209 2835
                  Matt 0421 743 825
                  I've used these guys a few times for production work and they aren't bad. Often quite cheap.
                  - Mike
                    Thanks for your help guys. I tried the search feature but couldn’t find anything. I’ll give these guys a go. Thanks very much.
                      I just did some aluminium rims myself. Stripped the clear laquer off with a wire brush on a drill and then sanded 240/400/800/1200 ....some by machine some by hand. Then used Josco Brown polishing compound (Bunnings I/N: 6327107) on a a felt pad on my angle grinder which brought my metal to a mirror finish.
                      Rob
