Hyosung GT650R LED Indicator Install Problem. It won't fit!!!
  • Hyosung GT650R LED Indicator Install Problem. It won't fit!!!
    Sup guys!
    I've bought some indicators for my Hyosung GT650R and they don't fit.
    The bolt size of the LED indicators is 10mm. The stock indicator bolt size is 5mm. I've had a good look online for different sizes but every LED indicator I've found has a 10mm bolt. It seems as though the 10mm bolt size is universal. Anyone had this problem? Do people drill into the fairing and front dome frame to upgrade their indicators? Seems a bit excessive.
    Any help would be great!
    Why do you want to change them, if it seems too much to pull out a drill an encourage them to fit?
    if it was me I’d drill it without a second thought
      Because they look nicer? Because they give off more light? For fun?
      Why are countless numbers of LED indicators advertised to fit my bike but don't? They should be a direct plug and play. I'd rather avoid drilling but it might be the only way, that's what I am trying to find out here.
        After digging deeper on youtube drilling is the only way. Still seems excessive but if it has to be done, it has to be done. I am off to find my drill.
