Carb Jetting
  • Carb Jetting
    i have heared that you should allways re-jet the carbs when you put on a new exhaust. I have a feeling that the previous owner who put dual "Shadow" exhaust (made locally i believe) did not do this, and i suspect that the mighty twin is runnig failry rich, as the cans are caked with carbon buildup.
    1) what are the ramifications of rich running?
    2) where do i get the carbs re-jeteed (dyno jet make a starge 1 needle thing)
    3) how hard is is (can i do it myself)
    4) how much
    thanks
    (\__/)
    (")_(")
    Thats allot of questions :shock:
    wouldnt it be easier 2 get a new bike?
      TRX, in about 10 days we will have a resident mechanic on the forum who will answer all these types of post.
      Keep an eye on the new Forum topic when it starts.
        Who's the mechanic??
        Man ,you were flying when I went past you
          Great idea.
          NO! ive only had it for 3 months, and i luuuuuuuvvvvvv my trx
          (\__/)
          (")_(")
            All to be disclosed in good time....
              TRX 8-fiddy
              The best 4 stroke Tuner that I know in Perth is Russel
              from Dynotime in Wangara - always best 2 see a pro with a dyno
              I also Know that it is better to run rich than lean
              as the later causes to much heat build up which can
              lead to melting upper cylinder components.
              Dont know $ though
              guess I shoulda wrote this b4 :roll:
              Just didnt know if u liked the bike or not
