eletrical problem on cbr250rr mc22
  • eletrical problem on cbr250rr mc22
    Hi,
    I'm having some sort of electrical problem with my cbr. What i need to know does my bike have an alternator or something as i think its fucked
    Elaborate on your problems and you may get a sensible answer.
    EDIT: Honda. It's your regulator/rectifier.
      Yes, you do have an alternator (someone correct me if my assumption is completely wrong).
      But what exactly is the problem? Battery not recharging?
      *EDIT* VV Way outta my league... Desmo? =P
        thanks Desmogod,
        I was looking for the name as i believe this is the problem.
        Battery wont hold charge, When i push start or jump start the bike will start but if i try to ride it, it has no power wont rev, and the electrics go all crazy (lights dim, indicator flash funny etc). However sometimes it will work then cut out as im riding
        is it possible to repair it ?
          Suggest you find the workshop manual for you bike (i'm sure it will be on the inter web somewhere) download it and have a bit of a read.
            have got myself one just needed to know the name of the part
              Originally posted by Pips View Post
              thanks Desmogod,
              Regulators are repaired through replacment however do you know how old the battery is? No holding charge is usually a battery problem not getting charged is a charging system problem. If you can borrow a battery charger give the battery a charge I think would be the first piont of call, or get your battery load tested.
              While your at check the battery leads havn't come loose or similar basic stupid problem.
                Do you have a multimeter?
                  yeah have done this, charge the battery, take the bike for a ride come back stop the bike try to start it and wont start. battery is less than a year old
                    yep
                      What voltage is across your battery?
                        bike running or off?
                          Off.
                          There should also be a procedure in your manual for testing your reg/rec.
                            http://www.perthstreetbikes.com/foru...g-guide-79463/
                            Let me know if you need a hand testing, I've done it a few times on mine
                              ^ Got your soldering fucking sussed Ben?
                              Originally posted by Ferris
                              I love how PSB has turned into "Dear Martha"
                              Figure shit out yourselves, retards.
