Leaking radiator
  • Leaking radiator
    Anyone know somewhere good to take a radiator, see if I can get it fixed.
    09 gixxer 750 radiator leaking as I was too lazy to get a radiator guard.
    Natrad in Osbourne Park do good radiator repair work.
    FTP
      Do a search 99% of radiator repiaers won't touch lightwieght curved radiators like the ones fitted to bikes there is one guy mentioned in a thread its entirely possible its beyond it. OEM ones aren't cheap ethier
        If it's an '09 model would it not be covered under warranty?
          By putting a stone through it?
          No.
          FTP
            I fixed one with JB Weld. It depends on size and location of hole. Drain it, take it off, blow it dry, and asses the damage. Could be piss easy, could be too far gone.
            EXPERIENCE: noun: Knowledge or skill derived from actual participation or direct contact rather than mere study, interest, or internet.
              an alternative to jb weld
              Dura Fix Aluminum Welding Aluminum Brazing Aluminum Soldering & Repair Rod
              Originally posted by Bendito
                Radiator is off bike, it leaks like hell, several small holes, 2 leaking badly, will sort it out this week. Thanks.
                  I took mine to Natrad in malaga, they clean around the holes, put a vaccum in it, suck in some resin, let it cure, pressure test, paint and there ya go, almost like new Think it cost about $50 from memory, dropped it off in the morning, had it back in the afternoon.
                    Will take it up there tomorrow or the next day.
                      had a pretty similar experience from natrad in armadale. sounds like they are the ones to take your busted radiator to.
