firing but not starting
  • firing but not starting
    hey guys i got a klx 300 road trail she will fire but will just not start any ideas its got new plug fuel ??
    iF yOu CaNt RaCe It Or TaKe It To BeD tHeN iT aInT wOrTh HaViN!!!
    by fire do you mean turn over?
    1:Which way do I go
    2:Whats the lap record.
      yeah
      it will just about start but not quite
        Check spark? check battery volts.
        1:Which way do I go
          sparks fine no bat kick start and doesnt have a bat to start with
            just had a similar thing with my kwaka... check fuel... clean the carbies?
            "Heaven doesn't want me, and hell is afraid I'll take over"
              new fuel and cleand carbie i was thinking could it be air to fuel mixture
                Possibly if there is crap in your main or pilot jet,(but you say carby is clean) when I say checked spark have you had the plug out and plugged into the HT lead then earthed to the engine and seen the spark quality?(make sure you hold the ht lead with insulated pliers or similar.). also what colour is the spark plug insulator?,is the plug wet?
                DJ
                1:Which way do I go
                  plugs fine i cleaned all the jets ill cheack again tomoz tho
                  it will sorta start like one barp then cut out it wont run tho
                    ok it seems it might be the timming is out aswell any one got any ideas how to do the timming on a klx
