howdy gang.
A while ago i bought a couple of pairs of 'shin yo' LED indicators. Yesterday i decided to put the front ones on. My bike is a 07 VTR 250.
Three things aren't right;
1. Flash frequency is double its usual rate
2. When i put hazards on, only half the LED's illuminate
3. The bike wouldnt turn over thismorning. And that was on the second start of the day, 5 minutes after turning it off after a 3 minute ride.
The indicators came with in-line resistors, which, as far as i know are supposed to correct the flashing frequency.. It was a simple wiring job, unplugging and plugging back in, so ive rulled out incorrect wiring.
My thoughts:
-The flash frequency may return to normal if i install the rear indicators (and their resistors)?
-The hazard flash supply is halved because all 4 lights are being operated?
-as for the battery going flat, i dont know. How can i have a leak in the circuit?
I will try plugging the rears in and see what happens. in the meantime; any help would be great.
thanks!
My thoughts:
thanks!
