VTR 250 front brake noise
  • VTR 250 front brake noise
    Hey dudes,
    just wondering why i would be hearing a click noise when i use my front brake sometimes. It only generally happens at speed of a about 40km's and stop after u hold the brake down, as in it just clicks when you pull the lever. Just wondering if anyone has ever experienced or got an idea why this would be happening? even better what i could check?
    Nothing to see... Move along...
    Christianity... It's just one woman's lie about having an affair that got seriously out of hand.
      Originally posted by wannabee View Post
      Brake cable not sitting in your lever properly?!
      Possibly the seals on the forks are sticking and "cracking" the seal as u brake...
      ...:mellow: No.
      It'll be the pad shifting slightly in the caliper, on the retaining pins. Don't worry about it.
      FTP
        Now that you mention it i thought i noticed some cracks around the rubber parts on the fork hmmmm time for a service by Derek and a quick check over me thinks.
          Please don't listen to Wannabee. He's an idiot.
          It can't be your "brake cable" because your bike doesn't have one. Your bike has a hydraulic brake system, which means no cable.
          And provided you can't see fork oil on your stanchions (the smaller diameter part of your forks), your fork seals are fine. They won't make a cracking noise when your brake.
          Check the brake pad's play, in a direction parallel with your brake rotor. If it moves a little, that will be what makes the noise when you first touch your brakes, when the pad shifts all the way forward.
          FTP
            Cheers Timbo, I'll have a look tomorrow when i have some good light. Sorry, just a bit of a hypochondriac.
              No worries. Better to ask questions than have something like that fail
              FTP
                +1, it bugged me for ages untill i wedged something (temporarily of course) in between the pads and the retaining pins / caliper.
