I've recently/finally replaced the grips on my bike and thought hey nows a good time to get rid of the sticking throttle problem I've had.
Problem is this - When I get rid of the sticking in the throttle there's a ton of play in the throttle (at least 10mm). If I reduce the play the throttle starts to stick again.
When I did the grips I pulled apart all the throttle assembly and it all seems fine and everything was moving easy. Cables can be pulled and pushed easily I then pulled the throttle assenbly part another two times to make sure it was put together correctly. It was.
NOTE: this problem was present BEFORE I changed the grips, I just tolerated the sticking.
Any ideas what I can do next ??
