Pinhole in oil cooler
  • Pinhole in oil cooler
    Devcon OK?
    Acceptable
    Make sure it is very clean, and rough up the surface a bit so the devcon has something to key into.
    Exmouth should have someone with a TIG that can wels aluminium
    Bert
    Hunter S. Thompson
      Heaps of boats up here so it would make sense
        Devcon will wick the oil eventually.
        Welding would be your safest bet.
        A cynic is a man who, when he smells flowers, looks around for a coffin.
        Dear god, it's some weird bastardized three wheeled two person go-kart.
          get new one will beat that!
          Or get it recored and welded if need be.
          No oil means No$$ (left)
            Leo's radiators in Wangara have always looked after me. Can't see them charging you anything more than $20 (Probably like $10) to weld a pinhole. They will even pressurize it and submerse it and find all leaks and sort it out.
            Originally posted by darkfibre
            Just sync the oil changes with her monthly cycle and get all the grumpyness over with, leaving the rest of the month clear sailing.
