Blackbird brake bleeding
  • Blackbird brake bleeding
    About to change the brake fluid in the bird and was wondering what the go was for bleeding the combined brake systems that honda have on these things?
    Just follow the user manual.
    It's not a hard job, you just need to bleed the system at 5 or 6 points instead of 2.
      Apparently a vacuum bleeder makes it easier than the old lever pump method
      Originally posted by Phildo
      Originally posted by filbert
        I made a pressure bleeder, still have it...did my VFR800 CBS system with it, was OK what I did but I have new bits for it that would make it seal better than it did when I used it, found myself watching the levels anxiously for a spill that might happen,
        Some tinkering and it should work well though
          Dud its easier to just pay a Mechanic to do it.
