Sticky Throttle needs unsticking - Help!
  • Sticky Throttle needs unsticking - Help!
    Have sprayed inox down the cables, have cut a bit off the grip, the tube appears to move freely in the switchblock.
    An other suggestions?
    Will take tank off soon to check the cable routing & the other end, but if I can avoid it that would be super.
    Thanks
    get matt to sort it out this weekend?
    Duct tape is like the Force it's dark on one side, light on the other and holds the universe together.
      Has to be tonight, track day tomorrow (nothing like leaving it to the last minute!)
        just wheelie it dude
        dianella 93703770
          Do it the dodgy way and put another return spring on yer throttle body/carby ?
          Disconnect the cable from the throttle body/carby/carbies and see if they are returning by themselves, you can then also pull your switch block apart and see if the cable is running freely without any load on it.
          You should never spray inox or any lubricants down cables etc, it generally will cause you no end of grief later on. If the cable is dry, graphite powder is the trick
            Sorted, cables were pinched under the airbox from the last time I had it off
            Thanks for the tips
              ^^^^^ that would be right, bloody back yard mechanics
                Or do it properly and fix it.
                  wrong person
                  sorry sorry sorry
                  dianella 93703770
                    Just a bit of trial and error that's all
                      Thanks for the tips
                      you crack me up dude
                      glad you got it sorted, good luck at the track today
