Carb clean - replace knock pins/cotter pins/orings?
  • Carb clean - replace knock pins/cotter pins/orings?
    Do you replace these items when cleaning carbs?
    If so, do you have to? (I am le poor)
    No you don't have to, but I'd say it's worth the money - they're not exactly expensive, surely?
      I'll be asking the local tomorrow if they have them in stock etc but if they don't I just wna know so I don't pull off the carbs and then not have a running bike (:
        O rings are usually ok unless pinched or deteriorated, fuel orings usually expand a bit when dried out so if it doesn't fit where it came out of dip it in fuel. Knock pins I'm assuming the R style clips are designed to be reused and similar to Orings, split pins (cotter pins) are usually single use only but in a pinch can be reused. Normally a carb kit will come with all the bits that usually need replacing gaskets seats etc etc.
