My bike (WR426F) runs pretty high idle RPM's. It starts OK but it hangs after riding for a bit.
Just confused about which direction does what on the Idle speed knob and I need someone to confirm if what im thinking is correct.
I got info from here: <The dreaded 'Hanging Idle' and how to eliminate it - WR 400/426/450 - ThumperTalk>
But there's still some clarification I need.
This pic is from the Yamaha manual.
Direction (a) increases idle speed (turn screw in)
Direction (b) decreases idle speed (turn screw out)
If I turn the screw IN and increase speed, does it mean I am taking in more air and making the idle mix relatively leaner? Too Lean = Fast = Burnt smell?
If I turn the screw OUT and decrease speed, does it mean I am taking in less air and making the idle mix relatively richer? Too Rich = Slow/Stall = Fuel smell = Backfire?
Also when I decelerate, the exhaust gurgles a little followed by 2-3 popping sounds. Its not a full on "BANG" backfire that I've heard others do before. Is that normal? The exhaust pipe is stock.
