VTR 250 not starting well.
  • VTR 250 not starting well.
    Bike was not used for 3 weeks and now does not start so well. Only does after a few dozen tries. Just clean the spark plugs or is there anything else to check out?
    check the battery and give it a good ride to clear the carbs abit. u might have got fuel varnishing in the carbs so your passage ways are half size or so. when it starts u could run it then stop and check the plugs to see if its running lean.
      Hey mate, get yourself a copy of the VTR250 workshop manual if you don't already have one:
      http://www.timdoyle.net.au/pdfs/VTR2...hop_Manual.pdf
      Should help with diagnosing any problems.
