Hey guys, i got a hyosung gt250r and have just changed the oil, oil filter, battery and spark plugs. but now when i start it up it either stalls when i put it in first gear or if i do get it in gear it has no power when i accelerate. any help would be appreciated.
No power!!!
one of the little tubes coming from your carby is a vacuum line which should suck when you turn the engine over.
You need to connect this to your fuel petcock as the vacuum open the fuel line and allows the fuel to flow fast.
If you don't have this line connected you might be able to idle it but not much more than that.
Look on the bottom of your tank on the fuel tap more closely there should be a small tube where the line can attach.Wes
