GPX Tacho, Dash headlights and indicators not working
  • GPX Tacho, Dash headlights and indicators not working
    So good news.. another problem with my GPX (EX250)
    I turned it on this morning and started riding to work and realised my dash , tacho , headlights and indicators lights are all not working and the bike is running like absolute shit as well.
    When I get home I will check the fusses, could it be a bad earth?
    Any ideas
    You're on the right track mate, I'd start with the fuses, otherwise it might be a bad earth
      agree with the fuses, could also be a shorting problem somewhere
        I dont think it would be a simple fuse issue if it is affecting how the bike runs. Everytime I've blown a fuse, either the engine runs fine or it doesn't run at all.
          Some water somewhere???
            I went to start it this arvo and its all working might be some water...
                this might be helpfull
                Download PDF Kawasaki GPX250 Service Manual | PDFTown.com
                cheers
                  hopefully its just fuses or loose connections, and not that someone has put a brighter headlight bulb in which has melted the fusebox and/or wiring loom.
                  someone did that to the commodore i used to own.... not cool.
