need a crankshaft re build where to go
  • need a crankshaft re build where to go
    hi there started my top end rebuild only to find both barrels had it got new barrels but i think i might as well get the crank done to ,wheres a good place to go and wots a good price to pay and is there anything else i should do well im in there
    cheers rich
    Ray Eason M/C engineering
    U2a 160 Beechborord Nrth.
    beechboro
    92728466.
      What Bert said or Gavin at GD engineering.
        just following up what jamathi and nath said. i'll vouch for ray here it hit me around the 900 mark to get my engine set up properly (included a couple bearings and piston rings), but i have no doubt that the engine is working well because ray has done it properly. almost 300km on the track, and it hasnt missed a beat (well, not because of ray's work)
        Originally posted by Pkunk
        It is a SCIENTIFIC FACT that all blondes with good bodies look 80000000000000000000000x without blonde hair
          i am also chasing a crankshaft rebuild but on a 3 cylinder crank 40hp yamaha outboard 2 stroke. I have rang at least 20 people and everyone has said no. Anyone can help me give me a call 0474936636
            there are 2 problems with outboard crank rebuilds
            1 : engineers usually have to make up a custom jig to press the cranks apart, a fair bit of time & expense involved so unless the workshop has one they wont be interested
            2 : older outboards can be a nightmare sourcing parts as they are usually discontinued as a OEM item and after market can be hard to track down
            good luck, have you tried the grumpy scottsman at Hamish engineering? he's not there all the time these days and doesn't answer the phone so you would have to drop in and have a chat
              Try Harris Engines - they seem to be pretty well set up and flexible. Had a few things for a little thumper done there and was very happy with their service.
              + they have a tidy and clean workshop, that usually tells a lot about the workmanship!
                Noztec in Welshpool. I have had a vtwin crackshaft done and a V10 crankshaft done also.
                Amazing work and pleasure to deal with. He will let you know if it is fixable straight off the bat.
