NWTK: How to drill a hole thru a double brick wall for a dryer vent?
  • #31
    Where are you located?
    Sent from my SM-G930F using Tapatalk
    • #32
      Originally posted by keys View Post
      Bunnings sell double brick wall holes ...
      Do they sell them individually or in a pack?
      • #33
        Need to ensure you buy the kits that include the holes for both leaves of brickwork.
        If you ensure to tell Bunnings you require the hole for double penetration they should be able to point you in the right direction.
        • #34
          I think they were in aisle 6 next to the cans of compression....
          • #35
            Depends on the type of brick..too. Bricks are not created equally.
            Home Hardware have poly drills..that can be used on soft brick..and yeh make sure the you use the double brick hole drill set for this type of hole. ( keep birds in cage if using Poly-Drills..)
            Use marine grade silicon and add brick dust while still wet to blend into colour of wall for a neat effect.
