Led Torches
  • #61
    Originally posted by Halo_2 View Post
    Led Lenser range is the bomb got the H14R.2
    Used to think the same but after 2 of the P6 (dual AA) having issues with the switch start playing up and not being able to get spares (or even a reply from Lenser!) I decided to try the 5.11 Been good so far and I at least can get a replacement end cap switch for it
    Originally posted by Phildo
    Originally posted by filbert
    • #62
      The Nitecores come with a spare tail switch and spare o rings, I'm sure they're not the only ones to come with spares these days.
      Originally posted by Commander Keen
      "IF YOU DONT LOVE ROSSI YOU'RE A TERRORIST!!!!1!!1!one"
      • #63
        My enthusiasm for a torch is inverse to it's size.
        Nitecore TIP. 500mAh Lion USB rechargeable, multi-mode, key-chain torch... max at 320 lumens!?
        Hmmm, makes my hand look big
        edit: Of course the 1 lumen for 46 hours mode is arguably more useful day to day
        • #64
          I actually just grabbed one of these as well... was going to post it up but you beat me to it!!! I grabbed one to sit in the car glove box and can be charged via USB.
          The other purchase was this monster:
          http://www.banggood.com/Convoy-L6-XH...l?rmmds=search
          I got it on special for $64.. man this thing is bright!!!
          • #65
            Nitecore TIP.
            Cool. Might have to get one for the car.
            $50 on catchoftheday ATM.
            Both of my P7s have been destroyed through battery leakage.
            Not going to replace them - as good as they were.
            I have an H14.2 that is my goto headlamp for camping etc...
            • #66
              I've got a mini Led Lenser F5. It's bright... but I also have a HID torch that's as big as my arm... its a damn spotlight! You could cook an egg on the lens after about 1 minute of use too.
              Sent from my SM-G935F using Tapatalk
              • #67
                Update:
                I rocked that little puppy doing a midnight shoot up at the Pinnacles. I had a high output torch for light-painting duties but needed something with lower outputs simply for getting around in the dark without killing my night-vision. The flat form-factor and light weight makes it comfortable to hold in your mouth for hands-free use.
                Has a battery indicator (internal led flashes) - and after a full night's use and a few days of messing about testing etc it still is above 50% charge. Only issue is that it can turn on in your pocket unless you use the lockout function, so perhaps flusher buttons would have been better.
                • #68
                  I was reading up on this and the lock out, instant hi and low functions make it real user friendly too. I' considering gifting my little BT-01 and buying one of these.
                  • #69
                    The TIP is a good little addition. Like it.
                    • #70
                      Just another shout out for the TIP.
                      Been using them a fair bit lately, around the house, at work, 4WDing...
                      I've got four now.
                      They're in bags and cars all over the place.
                      Awesome punch for such a small torch, and I almost can't remember the last time I charged any of them.
                      The new ones by default have a 30 second auto-off setting, just in case you turn it on by accident.
                      It can be over-ridden by pressing and holding both buttons (light will flash twice).
                      Also has a 'clip' now that you can use to attach it to a hat visor or chain... or extend to hold it between your teeth if that's your thing.
                      • #71
                        Been using 5.11 torches for a while now at work and around the house/shed and find them great
                        I have an XBT-A2 and a TMT-A2 I use for work, an XBT-A2 in the house and a TMT-PL Penlight in the car for emergencies
                        I like the fact the A2 just take 2 x AA batteries which are easy to source (and free from work if I can find them) and the PL just takes a AAA No need for fancy/expensive/hard to obtain batteries
                        • #72
                          i got a few of those cree t6, only cheap like $20 each but seem to do the job
